Hotel in Budapest
I’ve created a set of images for this project designed by Roomba Home Studio but I wasn’t really satisfied with the wide angle shots so I came up with a couple more interesting shots which ended up like this..
https://www.behance.net/gallery/69779961/Hotel-in-Budapest
C&C appreciated
ps: have you seen these cool banana leaves already? :smiley:
LOVE it
Bravo! A fantastic set!
May I ask how you lit the scene?
D.
Thank you!
It’s a simple Corona Sun/Env. My only “trick” was that I put the corona sun in Lightmix so I could control (lower) it separately. Rest is IES
Fantastic work.
Love the plaster on the walls. What texture did you use? Is there any bump or normals map?
Also the plants look great. Custom model or from a catalog?
What noise level did u render to?
Nice work bulyfabi. If the book’s placement was ok then the third image could have been correct and 4th image bumb map above on the door.
Thanks!
Yeah, I know those mistakes unfortunately.. On the close up image the books and the bookshelf is fixed and remodeled.. I’ll rerender the old one soon :slight_smile:
Thanks!
The wall texture is from this scene http://triangleform.com/product/vol-2-home-equipment-interior-scene/. Diffuse is two layers in composite. Fist is CoronaColor, second is wall texture with multiply blending 30-50% opacity. Bump is just the b&w wall texture alone. Simple.
Plants are mainly from 3dsky except the famous banana leaves. It’s from Jakub Cech
I usually go for 3% noise level.
stunningly Beautiful… Love the Colour palette. Great Visuals
Thanks!
