Hotkey capture issue
could it be possible that the hotkey for screen capture is global saved and constant for all saved setups? I have the problem that I can’t save some key combinations anymore (Enscape doesn’t accept it anymore) and I need to use a new one. So I have different key combinations at different saved setups.
-Micha
@Micha that could result in some conflicts with other key combinations if you’re using multiple basic programs of Enscape on your workstation.
@Jonathan_Knoefel I ask for it because some times Enscape doesn’t accept if I try to set my combination again like used before. Maybe this can be solved and so I can set Ctrl+Shift+p or Ctrl+Shift-F11 always.
@Micha we’ll check on that. What kind of message do you receive when you try to set those hotkeys?
@Jonathan_Knoefel Only it doesn’t accept the input without a message, only it doesn’t show the key combination at the line.
I tested it today and found the reason - if I have opened two Rhino tasks → check or set the hotkey to Ctrl+Shift+P at the first task → go to the second task → hotkey is shown as [none] and Ctrl + Shift+P can be set. I suppose so Enscape doesn’t allow to set an used hotkey, but it “oversee” that it is used by an other Enscape task only.
I’m using several Rhino task at the same time very often, since I’m working on different projects at the same time very often. I hope it can be fixed. Good luck.
@Micha Thanks for your detailed description!
Sometimes I have this problem as well. I usually set “`” (oemtilde) as my screenshot key. Sometime it keeps it, sometimes I have to reset it, sometimes I have to use “shift + oemtilde” and even sometimes I have to use “ctrl + oemtilde” All with only one enscape window up. Seems random.
Not a big deal, just letting you guys know I have a similar issue.
I’ve seen the same issue.
The screenshot hotkey was introduced back in a time, when Enscape only supported Revit. With Revit having multi-document support, there was mostly only one Enscape instance opened. So it made sense to have a global hotkey. Right now the global hotkey is registered during CAD software startup or after a change to the hotkey setting. But if the hotkey is already registered, this fails.
But I can see how this changes with SketchUp and Rhino in the mix. We will think about a solution. Thanks for pointing out the problem.
Thanks for the explanation! Appreciate it.
