Hotkey for "Select Vray camera" possible?
I am desperately missing a hotkey to select the active vray camera.
Is that possible? Or maybe with a scripted?
Here you go.
You will notice i left you a second version of the macroscript commented out.
Copy the contents in another script, and run it, to have a second command available which will select the active camera regardless of its class.
EDIT: Latest version is v 0.02. It’s been strengthened for when the current viewport is not a camera one.
It will proceed looking for other views which are a camera, and select the first one it finds.
If it finds none, it will select the first camera it finds (i.e. it’s been created first. I think.) in the scene, even if they aren’t set to a viewport.
If it finds none, it will pop a message box, and warn the user.
Keep reporting issues, thanks!
selectActivePhyscam_002.zip (608 Bytes)
many thanks! :slight_smile: I will check it out tomorrow
Just to add to Lele comment , I suggest adding Try() Catch() to the script like this
try(select (getActiveCamera())) catch()
to avoid an error if you are currently not looking through a camera.
Personally, I use the following script all the time :
http://www.scriptspot.com/3ds-max/sc…-active-camera
bah me. i thought it’d work with an undefined selection.
Let me fix this, and also try and figure out what happens with multiple cameras.
Note you can also select the camera you are currently looking through from the dropdown menu in the view.
Many thanks!
I just tested it now and it works great. Even with several cameras and with or without the additonal “catch”-line. (3dsMax2021)
I did not check out the script from scriptspot, but thanks also for that.
V002 should work fine, yes, no need to edit it.
