[HOU-2793] Displacement with TriPlanars tearing mesh apart
I struggled the whole weekend with a displacement problem. I’m using some mixed TriPlanars and the result is that the mesh gets torn, thousands of (micro) holes. I tried to fiddle around with these options:
- With and without displacement shift (small negative values)
- Displacement edge length
- Normals in all variations
- Cranking up the base resolution of the mesh to insane values
- Used only 1 TriPlanar (no mix of many) and set the texture blur to 1 to get that smoothed out
The only thing that works: Lowering the resolution of the mesh and smoothing it out while loosing too much detail. That is not an option. So how can I get rid of this?
Screenshots + .hip file may help a lot.
Where can I send the hip to? Upload in here is not possible due to size limitations. (Filesize is around 25MB)
There is an email in my signature andrei.izrantcev@chaosgroup.com you could send files there or to support@chaosgroup.com.
Dear @sebastian_orosz , hello.
Excuse us for the delayed response.
I have investigated you scene and made similar setup in 3dsMax for comparison.
Could approve the following:
  • the white artifacts are visible, yes
  • normals are okay
  • with other displacement textures the artifacts are seen, but in different amount
  • decreasing the Displacement amount will limit the artifacts
  • converting the geo to other formats could also limit the artifacts
In conclusion, details about the geo will be highly appreciated - its creation process or where it is gathered from.
If it’s made by you through a simulation, please share with us the .hip again by e-mail and use V-Ray > Pack Scene.
The geometry type, scale and units have to be considered once more to define the issue.
In addition, I have logged it in our system for further investigation.
Hope it won’t cause you any inconvenience to share the requested above.
TS
Is this problem solved or any news?
I hit the similar issue with Vray 7.20.10 for Houdni Solaris 19.5.605.
In my case, turning off Motion blur is the solution but I don’t want to turn it off so am looking for the other solution, then found this post.
