Houdini 18
Hi. Where I can find version for Houdini 18?
You could download V-Ray for Houdini 18 in our nightlies section nightlies.chaosgroup.com .
I dont’s see nightlies for Houdini. only stable build for 17
Then please write to support and they’ll activate those for you.
I’m new here but I don’t understand this attitude, I asked to get access to nightlies section,Interested in V-Ray for Houdini 18,
The give me the nightlies link but there is no V-Ray for Houdini 18,
I’m not sure it’s an attitude, but rather a nightly server issues or smth.
Try relogin to the nighly server, is this won’t help it’s may be better to write back to support so that could figure it out.
I’ve uploaded a few builds here: https://drive.google.com/open?id=16LxHJDKVXoZvVXHfZML9ab4HfOFaHCx7
And hope your access will be resolved asap.
thank you I’m downloading now
Does not seem to work with Houdini 18.4016
Here is my .json file
“env”:[
    {“VFH_ROOT”: “C:/vray”},
    {“VRAY_APPSDK”: “${VFH_ROOT}/appsdk”},
    {“VRAY_OSL_PATH”: “${VRAY_APPSDK}/bin”},
     {“VRAY_UI_DS_PATH”: “${VFH_ROOT}/ui”},
     {“VFH_HOME”:“${VFH_ROOT}/vfh_home”},
     {“VFH_PATH”: “${VFH_HOME}/bin;${VRAY_APPSDK}/bin”},
       {“PATH”: “${VFH_PATH};${PATH};%PATH%;%QT_QPA_PLATFORM_PLUGIN_PATH%”},
     {“HOUDINI_PATH”: “${VFH_HOME};${HOUDINI_PATH};&”},
    {“PYTHONPATH” : “${VRAY_APPSDK}/python27;${PYTHONPATH}”},
    {“HOUDINI13_VOLUME_COMPATIBILITY”: “1” },
    {“HDF5_DISABLE_VERSION_CHECK”:“1”},
    {“QT_QPA_PLATFORM_PLUGIN_PATH”:“C:/vray/qt”},
    {“VRAY_FOR_HOUDINI_LOG_FILE_NAME”: “vrayLog.txt”},
    {“VRAY_FOR_HOUDINI_LOG_FILE_PATH”: “C:/vray/log”}
but nothing in Houdini shell, what I doing wrong?
Oh my bad I’ve double json file
work like a charm thank you
yes work like a charm
Can you provide me a link V-Ray for Houdini 17.5 460 windows ?
thank you
elrachyd, uploading to the same gdrive directory, should be there in half an our or so.
nice! Thank you
