The specific crash we would like to address is connected to rendering with IPR and scrubbing the timeline.
This should be easily replicated by creating a cube a camera and a VRay ROP. When you start the VFB and start a IPR rendering and then scrub the timeline back and forth we get a crash to windows desktop without any crash windows etc.
Would you share with us a screenshot of V-Ray > About V-Ray menu?
Also, did you make any change prior the beginning of the crashes? Updated a software, replaced a hardware?
Does this crash happen with every set-ups or just with specific scenes?
How often are you experiencing this crash? On every opening or from time to time?
Maybe we need to perform more attempts in order to catch it…
As Viktor requested, please paste here the information from About V-Ray menu.
Hi again,
This specific issue happens with every Houdini scene, that’s why we can test it with an almost empty scene.
I wanted todo some more tests with different Houdini/VRay versions before getting back to you on this specific issue.
I’ve tested some more combinations, and going back to Houdini 19.5.435 with (
V-Ray for Houdini number:22276 hash:74edd4a from 07 Feb 2023 01:59
V-Ray Core 6.00.21 from 3 Feb 2023
works fine when scrubbing the timeline, so no issues there.
I also wanted to test a installation of Houdini 20.0.506 with (vray_adv_61009_houdini20.0.506_1ff6d23_22581) same crash there, but this time I got crash window in Houdini reporting “segmentation error 44652”.
And lastly I upgraded VRay for Houdini 20.0.506 with the latest stable build (vray_adv_61009_houdini20.0.506_eee8467_22595), and in this version of VRay scrubbing the timeline seems to work fine, I get no crash.
So maybe we should test installing vray_adv_61009_houdini19.5.682_eee8467_22595, and see if this helps for our current Houdini version.
We’ve been having other issues for quite some time with the Houdini UI freezing and hanging when using the VFB, resulting in us having to force quit Houdini. These issues are harder to reproduce though and involves more heavy/complex scenes.
I’ll get back on this once we have more input on these issues.
Have you noticed any crash notifications when closing files (with or without Saving changes)?
Quick test will be to open a new or existing file, run a render and then close it.
I have Rocky Linux 8.x.
Make sure your Houdini compiler ID is matching V-Ray (e.g. if Houdini installer has gcc11 in name you have to use VFH build with gcc11 in name).
Same problem here,houdini crash when moving VFB or open /close side bar,even when not ipr rendering sometimes.here are some info and screen shot. VFB_Crash.zip (4.7 MB)
I’m using the 20240228 version, Again, still have the same problem.but it’s better now,I can still reproduce the crash by the follewing step:
step 1: create a empty scene.
step 2 :create a vray rop and start vfb ipr.
step3: create a cam1 , a box ,a vray domelight.
step 4: frame the box using cam1,so the vfb can show the box .
step4: Quickly open and close the sidebar about 10 times.
Ticket was just created for you to our Chaos License Management team.
They will contact you shortly and you will be able to test latest changes as well.
