Hello--
I’ve used V-ray for Houdini since v18 (maybe earlier), and any Houdini installation that also has V-ray installed crashes when you click the node help button (the little question mark), or if you press F1. The console comes up and endlessly streams “ERROR: network_service_instance_impl.cc(262)] Network service crashed, restarting service” and the only way to stop it is to close Houdini. Is there a way to fix this, outside of having a second V-rayless Houdini install for help, and just never ever accidentally hitting F1?
This actually doesn’t happen on Houdini 19.5.303. So: that’s a good start! Any way to fix it in older versions?
I’m on Windows 10 on a fairly stout computer.
