House interior C&C are welcome!!!
Hello everyone! ;D
This is a recent work that I’m doing
It still in progress…just showing for the c&c.
Thanks.
Room
LivingRoom
Bedroom
Bathroom
Re: House interior C&C are welcome!!!
wow it looks very good, only one thing for me, the texture of the carpet in the bedroom.
;D
Thank’s ;D
The problem of the carpet…I think the same too, the problem of displacement and find a good displacement material makes me crazy to solve. Nothing that whith time I can solve :stuck_out_tongue:
Hi Ze :wink: I like your renders, you have a big progress. Some suggestions : you should use combination of Vray Sun + Rectangular light, to improve scene brightness. Your renders are a bit darker than should be. Another tip - you may use levels and curve correction in Photoshop.
For displacement - go to download section, and get a grass Vismat. In vismat folder you will find a wonderfull Bump texture. You may use it in displacement slot ;D
Thanks Alex for the tips ;D.
I really don’t use RecLight in the windows on this work, if that you mean…I will try :wink:
One more time thanks :slight_smile:
For the carpet you can try with rhino hair
http://liquidtectonics.blogspot.com/2009/05/its-been-while.html
;D
Thanks Davidooone :wink:
I will try that too.
Best
Hello!!!
Already done!!! Could be better, I now, but time line is over, lol. And I have to learn more, more and more… :stuck_out_tongue:
Some images…
House
Hall
Room
Kitchen, without no glass windows
Living Room
Pool
SuiteBedroom
Dressing Closet
WC Suite
Thanks and Sorry if this is not good to be here :slight_smile:
Next work I will improve more :wink:
Best
Hi Ze, the design is ok, i like this minimal tendency ;D But your brightness is still insufficient. For the next time, adjust light intensity boldly 8)
Best
thanks alex!!! ;D
I confess that I has a litle lazy… :-[
Next work I want to improve…AND I WILL IMPROVE ;D
Best,
I like your images, you have material tiling issues that I’m sure you are already aware of. Tweak these and the lighting and I think you have some superb renderings.
I like the renders but I think you should keep the camera straight. You can simply edit that in PS with free transform if the angle is not actually ment to be so dramatic ;D
very nice interiors I would just fix some Flor tiling.
Otherwise I like it.
Regards,
uros
