How can I access Vray render settings through MaxScript?
Is it possible to access all the render settings parameters through MaxScript? For example, I would like to make a script that includes changing the buckets size in the Vray render settings. However, I can’t find this function when I do “showproperties vr” in the MaxScript Listener. There’s just a funtion that enables/disables dynamic splitting.
Thanks! :slight_smile:
system_region_x and system_region_y are the properties that you need to change in order to modify the bucket size.
Thanks a bunch! So that’s why I didn’t find it at first. I thought the parameter would have “bucket” in the name. :slight_smile:
