How can i apply Corona material
Hello Guy and nice to meet you. I am a new Corona User, i just installed it few mins ago and i am trying to test it but i don’t even know where to locate the Corona material. Can anyone here help me?
thanks.
Keymaster is doing his best to make Corona a revolutionary rendering engine so he controversially put Corona materials in the material editor.
Thanks for your response but still you didn’t tell me what i need to do to get Corona material active in my 3D Max 2013.
thanks
Don’t understand why you ask this question again… You don’t know how to do with Max in all the cases ?
You know where is the material editor ? And where is the Assign Material to selection ? Look at this, Corona Mtl are the same that in Mental Ray or VRay… and remember : Google is your friend :smiley:
what the other guys said, Corona is deeply integrated into 3dsmax, that means you have to know 3dsmax to be able to operate it.
First you have to load Corona as your active renderer (google it based on any other renderer if you don’t know how).
Press “m” key on your keyboard and wait until material editor pops up, then press the big button that says “standard”. From the new window pick “CoronaMtl” or whatever material you need.
Thanks Maru and other guys, the mistake i made was. i thought corona material will be independent from standard Material just like Vray. so i never checked standard material option. But now everything is ok. i will soon post my work rendered with Corona.
What.
