How can I change the standard size of the asset editor
Is there a way to change the size of the asset editor and make it permanent? I always need to make it bigger and every-time I close the program go back to the standard small size, Is there a way to save it in some kind of preference?
Also the right side where there are the parameters, generally I make it bigger to see better the material sample but since the last update I cannot stretch it that way, the 2 arrows pop up for a split of a sec but I cannot grab anything
Hi @Kikoita ,
There is currently no way to save the height of the asset editor between sessions.
We can look into ways to allow it though.
…but since the last update I cannot stretch it that way, the 2 arrows pop up for a split of a sec but I cannot grab anything
Can you show which part exactly do you want to resize?
Is it the Asset Editor as a whole or just the Asset Preview pane?
We have issues with the resize arrows not showing in specific situations.
In most cases it is caused by non-standard OS Display Scaling.
Can you share what’s the current display scaling that you use?
To check it on Windows you can right-click on the desktop and open the Display settings window.
There just check scaling percentage in the Scale and layout section.
Also note that in most cases even though you don’t see the resize arrow, you can still resize.
Konstantin
Hi @konstantin_chaos
I would love to have that option so I don’t need to change it everytime
The part I cannot change now is the width of the asset preview, I can change only the height
When I move the cursor over the line it show the double arrows for a split of a sec but I cannot grab anything
My scale is 100%
