How can i create the effect of frosted glass or valance?
i want to create the effect of frosted glass or valance, which is ind of translucent but not that glazed, can i accomplish this in Enscape?
Hi @qiancy88 the keyword “frosted”,“marble” or “plastic” etc. don’t fit your needs?
You maybe have to play a little bit with the opacity of the material.
Hello @Jonathan Knoefel, I have the same problem with border of glass.
In this picture as you see border color is difference with FROSTED surface.
So i want to fix this, and how to control FROSTED density.
Because i has try many kind of but border of glass is nothing change.
Please help to fix,
Thank you!
Hi William, as far as I know what you see is an effect of DIFFRACTION of the glass,
I’m not sure you can achieve at the moment with Enscape…
There is a “cheat” to use a bump texture, it doesn’t work in all conditions though (if you have transparent or semitransparent materials in front or behind it.)
PLEASE PLEASE PLEASE implement the frosted glass effect
