The sky keeps getting cut out whenever I save a muti-layer exe out of vantage. This Vantage 3.2, livelink enabled, and opening the file in Photoshop user exr io.
How can I get it to show up properly. It shows up correctly if I export as any other file type with individual render element files.
I don’t have Photoshop, but I would guess it multiplies the color it shows by the alpha channel. The sky (environment) has alpha = 0. So you just have to tweak how the alpha is handled.
Sorry how would I go about doing this? Are you referring on the Vantage side or Photoshop side? When I render out in Vray everything works as intended. I only see this behavior with Vantage multi-layer exrs
I’m sorry, I’m not a Photoshop user. I rendered a simple exr in Vantage and it looks as expected in Chaos Player -- alpha is 1 only where there is some object and the sky has 0 alpha. The sky color is visible in the RGB channel.
