I get a simple room.when I render it, it’s hard to make it as good as cpu render. look the picture I upload, the darkness,highlight and the color of chair, all couldn’t Meet my expectations.
Any Help? How set the vantageSetting
the sample scene File (max 2020+vray5)
vantage.rar (872 KB)
From what I understand, you are using a bit of an unusual setup - there is no final gamma correction on the image, so you are looking at the linear output directly.
As far as I know, this is not a recommended setup for V-Ray either.
You can maybe use a LUT that increases the contrast of the image in Vantage to get a similar result.
Eventually, we might add a separate “contrast” post processing effect as well.
Greetings,
Vladimir Nedev
Post Processing features is highly required like Vray frame buffer post processing features and also similar to VFB+ plugin by Monotone Minimal. VFB+ has features like png overlays for watermarking images.
