How can i use softboxes , Reflectors , bounce cards in corona
Hi all
I read juraj saying that he uses soft boxes beside the daylight
How can i use softboxes in corona ! and how can i achieve depth in photo only rendered with artificial lights !
sorry for many questions ! hope u help me :smiley:
Corona light with rectangular or disc shape is basically the same as softbox in photography. “I’m using softboxes” is just a more fancy way to say that one uses additional artificial lighting.
thanks for ur reply ! but in vray i was using Hdri that has black from outside like the real softboxes !
what about reflectors ! Bounce cards ?
You can add gradient ramp map into Corona light’s texmap slot to dim the edges. Regarding bonce cards, usually simple plane with white Corona material is enough for that. What exactly do you want to know about them?
am very sorry for late reply .. i need to know how to use them in scenes like how can i put plane with white color in scene !
Create a plane and use a Corona Light Mtl, you can also use your hdr texture in the color slot, or a gradient as already mentioned and it will work. You can also use any texture on a light in Corona.
