How change the proxy color?
as in the title, how can we change the Proxy wireframe/point color?
With VRayProxy, the object color works as usual. In Corona is gray-out. :confused:
will take a look
Ok, thanks
fixed
Oh, great! It will be very useful!
In the last build, I cannot change the CoronaProxy WireColor
Also, with the Script, there are some problem with the save directory… =(
UP! It isn’t fixed, unfortunately.
I’ll take a look if you tell me 3dsmax version including servicepack and 3dsmax graphics driver you use :wink:
I use 3ds max2013 UP6, nvidia 560 and nitrous. But, the problem is that, when I click the wire color rectangle, nothing happens!
Fixed. I forgot to merge the original fix with the production code.
