How do I do an opacity map when I use Udim method?
I worked on the texture in the udim method
I worked on 1001 to 1005.
What should I do when the opacity map is included in the 1005 tiles only?
I pulled the file in Png format.
What should I do?​
You need to use the wildcard <UDIM>. Check docs.
