When I save rendered images the default saves the alpha channel and my model without sky. It there a way to save exactly what I see in the rendering…sky attached?
p.s. How do I post images???
Re: how do I export the image with sky attached?
just put “.jpg” behind the filename and it saves sky included.
If you don’t specify a file extension the rendering will be saved as .png and the sky seperately as alpha for compositing in Pshop.
Thanks!
hello,
same manip for animation ?
Adrien
Yes it would be the same for animation - in the Output tab you can choose a filename. If one is not provided we build one based on the model name and I believe we use png as the default file type - so if you want it to not be png you need to specify it.
