Pretty simple questions I guess, I need aliased z depth passes but my render will obviously need aliasing. I cant really set off two renders so Is there a way to achieve this? I’ve tried a few options but nothing is in there it seems?
In max, underneath the list of render elements you’ve used, there’s an “enable” and “enable filtering” option. Knock off enable filtering with your zdepth element selected and that’s you sorted.
