When you export the image after rendering you get the alpha and the rgb - without the atmosphere/vray sky like so…
however, i desire to use the sky, is this possible?
many thanks in advance.
D
D
Re: How do i get to ‘export’ the vray sky?
When you save it as a png you do get an alpha and one without the vray sky, but when you save it as a jpg for example you will keep the vray sky!
By the way what kind of building is this suppose to be? a school or something like that?
ah… will give that a whirl - i would asume there would be a vfb? channel for it…
Its a civil/family law court ‘complex’…
Just make sure your RGB channel is the only one on in your VFB. Even PNG exports will function the way you want, jpg is not necessary. Otherwise the result will be an alpha mask and an RGB channel with no sky-which is obviously not what you need.
