Need to make an infinite white studio surface.
Hey,
First create a large floor (I use a giant plane). Then apply the Corona “Shadowcatcher Material” to the said floor. Inside the Shadowcatcher set the mode to “Enviornment”, Alpha mode to “Always Solid”. Then plug in a basic corona material that will define the background (Usually its just a white diffuse material). Open up the render settings and under “Scene environment” find “Direct visibility override”. In there plug in that same basic corona material. Adjust that for the color of the background.
The plane is what is going to catch the shadows so technically you just need a “big enough” plane so that it covers all the areas where the objects will cast shadows. The basic material you’ll apply will define the background which will match the floor so you won’t see any seams of where the floor ends.
Hope that helps ![]()
Thanks so much for the help, but I am still getting a seam. Here is a scene file.
shadowcatcher test.c4d (196 KB)
modified your scene a bit (attached)
note:
take care
shadowcatchers_test.zip (131 KB)
Thank you for you time. Duly noted. I did notice that if I removed everything except the overhead light that the seamless background would be achieved. So I could see that my fill cards were causing shadows as well.
All the best,
Mike
