How do I match FOV to a camera Lens
Not sure if this is the right place to ask this question but a consultant asked what lens we were using for one of our renders.
Its for planning approval and they suggested a 50mm lens would be the most appropriate.
I found this article: https://blog.enscape3d.com/best-practices-finding-the-right-perspective#:~:text=The%20Enscape%20default%20is%2014.5mm%20which%20is%20a%2090%20degree%20FOV.
which talks about "A common camera lens used for architectural photography is 24mm (Tilt-Shift) which is a 67 degree FOV in Enscape. The Enscape default is 14.5mm which is a 90 degree FOV"
Does anyone know the best way to convert the FOV used in enscape to a camera lens?
Thanks in advance
Paul
