I’m doing day shots and the lights are on… How do I turn them off? Is there a setting or slider in the path that I can adjust?
Hello @Luma3d
Currently there aren’t any options to switch the lights on and off. We made them always enabled by default because the headlights should be dimm enough to not be visible in daylight and the break / turning lights should be always bright enough to be visible even in daylight, as it happens in reality.
That said, we understand it may sometimes not be necessary to see any lights in the renders, and switching them off can help optimizing render times. Therefore, I will forward a request to the Devs to add this option a future update, thanks for suggesting it.
