how do you build 3d-geometry(archviz)
I use splines in max. Usually i redraw everything from scratch from a 2d dwg template (with snap), because re-using CAD lines always results in some mess.
I outline the elevation/facade views, then i use the rectagle tool in “add to shape” mode to create openings. then i convert it to mesh, create a second mesh for glass (minus the outline shape), inset this mesh for window borders, etc.
After all facades are done, i turn and align them over the ground floor plan. then I put different push and shell modifiers over everything.
Architects often think that i just extrude their 2d plans to the right height and level. That wont work.
If I extrude something, then single polylines only, with a shell modifier applied to them, after extrusion.
Extruding CAD shapes almost never works nicely, because there will be some duplicate line segment somewhere, messing everything up.
Even if it works, how should i put the windows into the extruded edges?
Booleans are evil, I only use booleans if i have a very good reason. Rectangular windows are _not_ a good reason to use booleans, unless you want like to torture yourself, or enjoy fighting with software.
Sometimes I re-use meshed autocad hedges for things like terrain, streets. Depends on how clean they are.
