How do you change the folder of VRay materials?
Hello Newsgroup
I would like to change the folder VRAy has the material, options, etc from windows application data to the folder I have my other rhino stuff.
Namely from
C:\Documents and Settings\All Users\Application Data\ASGvis
To
C:\Rhino\Elements\Vray
Is this Possible?
Gary
Re: How do you change the folder of VRay materials?
No I don’t think there’s a way to do that…as a workaround, you can add a short cut to your folder within the default folder…thats the best I can think of at the moment.
Hi Dalomar
Thanks for the response and workaround. I see that the shortcut would work. But for the batch render to work I see that the materials you use and the options need to be in the defalt forder or the batch render does not work, No error message…just no results. So left the materials and options in the defalt folder. Then put the shortcut in my Rhino file to retrive the material and options folder for back up.
All the best
Gary
