Hey guys,
Quick question; how does enscape render videos out? I assume it’s all GPU based? Is it possible to have multiple instances of Sketchup/Enscape open and rendering out all at the same time?
Hey guys,
@Macker202 You’re right, it’s GPU only and you can open several Enscape windows on one machine to render simultaneously.
Excellent. Surely then, this is an argument for SLI? Or at least being able to select which card to render on? Otherwise you’re limiting yourself to 1 gpu per machine.
It’s one GPU per Enscape instance, but (depending on your system setup) it could be that if you open several Enscape windows, several GPUs are utilized.
I just tried and no, I have 2x 1080ti’s and I ran two instances of Enscape and both were only using my primary GPU, too bad we can not assign which GPU to use in settings or even better have Enscape use all GPU’s available.
This is a big issue for us. It means we’d need one new PC and Enscape license per “render node”; clearly a non-starter.
@solo75287 @Macker202 yeah it’s on our agenda.
