Just so I understand this correctly.
Each subscription is for 1 user only, but the license is floating so can be used by anywho is loged into said account? Just not at the same time?
Many Thanks,
Rich
Many Thanks,
Rich
Right, only one person can be using the license at any given time (in a “live” sense of being inside a full version of 3ds Max or C4D and working in it - the render nodes give you 3 other machines that can use the same license for network rendering, with a Backburner Client for Max or C4D Client for C4D). The same main license can be used on any machine, so long as it is only active on one machine at once.
For the future, it is always a good idea to check our helpdesk as the first step. See:
Workstation license - https://coronarenderer.freshdesk.com/support/solutions/articles/5000650527
Node license - https://coronarenderer.freshdesk.com/support/solutions/articles/5000650528
Floating license - https://coronarenderer.freshdesk.com/support/solutions/articles/5000650530
If you have any other questions, feel free to ask here or over support: https://coronarenderer.freshdesk.com/support/tickets/new
