What should be connected where? (And when will the docs be online?
The VrayWater node is a texture node, which you can use as an input to the Displacement node.
The only Vray specific thing is that you should change the displacement type for the shape to âVector Displacementâ.
You can access this parameter in the Vrayâs extra attributes:
Attribute editor â Attributes â VRay â Displacement control â Displacement type
Ive used it with normal displacement all the time, piping one of the colors to the displacement. Whats the difference? Is vector displ better?
At the moment only vector displacement will work.
Weâve implemented a wave choppiness parameter and this requires a 3d displacement.
Oh, nice, have been looking for better water solutions in maya vray , but thats sound good! Is it implemeted from nightlies 11538 ??
No, you need 11955+
Nice, thanks for the explanation. Any chance for some kind of viewport preview? Maybe just calculating a luminanceversion of the displacement for use as a bumpmap or something like that?
Try smaller values, 10 or 100 times smaller.
Whoaa! Nice stuff you´ve got here. Its alot better than the other water.
Any chance of making VrayWater part of the Vray Create menu like the other features (like fur, etc)? Would make it so much easier to use ![]()
and yeah! it does look pretty awesome ![]()
Using Vladoâs test-scene and with my Donut Man in a little refreshing dip ![]()
Anybody succeded to create some wave pinch/choppiness?
pechart: Try smaller values, until there is no choppiness at all, them choose a value that you like. If you canât fix it, please upload a test scene, so I can see what is wrong.
I really donât get it, sorry. I attached a very simple scene. Thank you!
water01.zip (12.1 KB)
You can try to set the height multiplier to 0.01, choppy multiplier to 0.00007 and patch size to 2560.
Also it seems that you have to delete the inner edge of you water plane.
In seems that Maya 2011 has a bug: setting small values in the Attribute editor doesnât work. If you set an attribute to 0.0001, the command that is executed is setAttr attr 0, not setAttr attr 0.0001. You can use the channel box or the Window > General Editors > Attribute Spread Sheet.
Hmm, okay. Iâll give that a try.
Itâs not a bug; you can specify the precision somewhere. Canât remember exactly the case, but there was either a global setting (like in 3ds Max), or it had to be specified when creating the parameter in the C++ code.
Channel Box > Edit > Settings > Change Precision?
what is the proper control to scale up or down the frequency, so that I can control the water scale in relation to my scene?
