How link VRayUserScalar or VRayUserColor to Transform?
Hi!
I need create link from VRayUserScalar or VRayUserColor to Transform attribute in placement node. Like UVWGenPlanarWorld.uvw_transform
If I create it in VRayUserColor scene and connect to placement translate it does not export.
If i do it in post translate, it’s does not working to))
userScalarTest = create(“TexUserScalar”, “userScalarTest”)
userScalarTest.set(‘default_value’, 0)
userScalarTest.set(‘user_attribute’, ‘userScalarTest’)
place = findByName(‘place3dTexture1’)[0]
place.set(‘uvw_transform’, Transform(Matrix(Vector(0.985, 0.174, userScalarTest),
Vector(-0.174, 0.985, 0.000000),
Vector(0.000000, 0.000000, 1.000000)),
Vector(-0.000000, -0.000000, -0.000000)))
I need control for mapping position form userAttr in proxy instances
Solved by UVWGenSwitch
V-Ray doesn’t support textures applied to transform parameters in most plugins.
The UVWGenSwitch approach should be fine.
