How to achieve VraySphericalfade effect using Vantage
Is there some way I can achieve VRay Spherical Fade effect using Vantage?
I am trying to re-render a part of the scene to add a few objects to the existing animation.
The VRaySphereFade is not supported in Vantage (nor in Standalone). You could use a VRayClipper with a Sphere (mesh mode; intersection operation) to render only things inside the sphere. However, I think it would be faster to just re-render the whole animation, especially if you need to animate the clipper, etc.
