Hello, I’m working with a unique shape that is illuminated and would like to add a mask with a soft edge to the light. How can I do that in Blender. I could do it in VRay for 3ds Max with a node. Thanks.
Hi jarrodw,
If you’d like to mask lights, you can use the Light Mix render channel. I’ll share our documentation with you below.
If you have any questions about using Light Mix, feel free to ask.
I’m not sure I’m actually helping with following but I try.
In Vray for 3dsmax you can add a texture to drive the lighten shape of the area light.
Have you checked if Vray for Blender give you the possibility to add an image in the light node?
Thanks for the clarification, now I understand what you’re asking. At the moment, this isn’t supported in V-Ray for Blender. However, you’re welcome to add it as a feature request in our Ideas Portal.
