Often, some render slave failed to render even when just before, during a crop test, all slave were working fine.
So, when the render takes several hours, having one or 2 slave less on top of 5, make a huge difference.
Is there a way to add other slaves on the fly to reach again the max slave number authorized by the license?
Here is another case where the slave won’t start.
I start a render (job B) on the Workstation, including DR, while the slave where busy with another job (Job A).
Once the job A is finish, the slave are free, but for some reason, they are not assigned to the job B still ongoing.
I would like to get the slave on duty for job B, but I have no idea how to do that.
What I tried so far:
Restart all slave: No progress, there is even no info visible on vray message regarding the restart
Open another max session, uncheck all slave from DR dialogue box: “Host Delete” from vray message
Add again all slave to DR: “Scene added” from vray message
But the result is the same, only the workstation is rendering, the slave won’t work “Host xxx not responding”
I tried rendering with DR from a new scene (job C) from the workstation (excluding the workstation because the workstation is already busy with Job B).
All slaves (5) are working.
To resume, Slaves works on a new scene, but won’t board on the job B on going.
Usually the message "not responding " by the salve machine is due to differences in the versions or Service packs V-Ray or 3DS Max or something that unsupported or missing on the render node/s.
Can you post the V-Ray log file form one of the problematic slaves as soon as one render (Job B) is completed?
What is the exact V-Ray build? In the latest SP 2 we have an option to add/remove DR servers on the fly.
Most probably the V-Ray log file is saved on different location. Do you start the V-Ray spowner manually or it is running as a service? If it is registered as a service, the file might be in the Windows/temp folder.
Probably the V-ray spawner is logged with different user account.
However, can you try to change the path (%temp%\VrayLog.txt), in the workstation render settings log section, with > C:\VrayLog.txt
and run a test render.
If you still have problems to find the latest log file on the render nodes, please email us at support@chaosgroup.com and we can check the system via remote control.
