# How to avoid particles getting inside of objects?
**URL:** <https://forums.chaos.com/t/how-to-avoid-particles-getting-inside-of-objects/53165>\
**Category:** Issues\
**Created:** [March 23, 2015, 8:10pm UTC](https://forums.chaos.com/t/how-to-avoid-particles-getting-inside-of-objects/53165 "2015-03-23T20:10:24Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![victorwol](https://dub1.discourse-cdn.com/chaosprd/user_avatar/forums.chaos.com/victorwol/32/19634_2.png) [@victorwol](https://forums.chaos.com/u/victorwol)\
**Post date:** [March 24, 2015, 5:36pm UTC](https://forums.chaos.com/t/how-to-avoid-particles-getting-inside-of-objects/53165/3 "2015-03-24T17:36:48Z")
</div>
yes… not only that, I’ll post the movie, there are several problems I can see.
water keeps dripping from inside of the emerging object like if it was faucet.
there is like a current where you can see water is clearly going to the left at high speed
you can see particles stuck in between the walls of the object.
the right side borders of the simulation are way to visible, and they change the height with the waves but they get stuck at a certain height. I know my box is small, I need to make it wider, but why they would stay stuck and why I have that current?
also I can clearly see the slopes of different heights of the water, that is kind of unusable as it is.
When I calculated this in low resolution, just a few cells, it looked completely different, so how can use design an effect and then when you are happy with it, up the resolution if the effect is going to be totally different. For example, on the low resolution, I didn’t see any slopes on the surface of the water, on the high resolution one I can clearly see steps.
Thanks for any help you can provide. I do really appreciate it.
https://www.youtube.com/embed/ClM1HE9MCEY?feature=oembed&wmode=opaque
I will provide the scene too in a few minutes.
_[View the full topic](https://forums.chaos.com/t/how-to-avoid-particles-getting-inside-of-objects/53165)._
