That’s right, I was not able to copy the BG. Would be cool if there were a simpler way. It would be cool to be able to export the VFB CC stack to PS. Thanks
You actually can export a .cube with all the corrections from the VFB. However, I couldn’t find a way to reproduce the exact same output with that .cube in PS. I hate that piece of software…
so is it not possible to save a jpg sequence with baked LUT corrections?
in this instance, would i have to save as 32bit EXR and then apply LUT in post? but even then it’s not possible to get the exact result as in the VFB when applying the same LUT file anyway?
saving out thousands of EXRs is going to take quite a bit of storage…
