How to comp vrayfastsss2?
Hello everyone,
How would like to know if someone know how to comp a a vraysss2 render elements with the diffusefilter pass,the rawlighting pass, the GI pass,…?
Because when I use the add or screen mode is a bit to shiny compared to the full render.
thanks a lot for your answers.
ps: sorry for my english
The sss2 element should be added to the rest of the channels. Note that the sss material may also produce a diffuse portion, which will go into the respective diffuse elements (lighting etc).
This is some screengrab from a flint 2009
When I comp a diffusefilter pass with the RAWGI pass I obtain a Vray GI pass
When I comp a VRAY SSS pass with a Specular pass I obtain my full render
Logically when I multiply my diffuse with my RawLight I obtain a lighting pass but in this case the lighting pass I render in the render element is black .
And if I try to comp all the layer with the sss I can’t reproduce my full render.
ps: sorry for my bad english
thanks a lot
Ok, I see the problem… the SSS shows in the diffuse filter element with its full color, which is what causes the problem. Will make a note to fix it, but until then you’ll have to mask the SSS object from the diffuse filter element.
Thanks a lot Vlado
I am happy to read this. I don’t use sss pass wit the diffuse filter anymore until there is an update.
thanks for your hard work
regards
mickael
