How to convert a VrayPhysicalCam to Stardard one ???
Hello guys,
I’m testing Ozone 4, and I need a Standard camera from an animated vray physical one …
Any idea ?
Best regards..
for the transformations you can parent your standardCam to the vray one.
Ok,
But how to match fov, etc… i want an exact match (i’m not using any deformation…)
When I tried it last the V-Ray cam worked fine with scanline and MR, except for distortion have you tried it with ozone?.
goto your vray cam, hit “P” then hit “ctrl c”
I’ve got an animated one..
Lele’s script pack does this with a converter tool! Yes, it does FOV etc.
I’ll take a look…
It seems to work…with a vrayphysicalcam…
Thanks.
Best regards…
When i want to match a standard cam to a physical cam I go in the vraycam view, then in perspective wich will match fov etc of your vray cam, then from there create camera from view and just link it to your physiccal cam! :wink:
