Hi.
I’m trying to use LIV (https://liv.tv/) to create an MR walkthrough in Enscape with a Samsung Odyssey HMD. Enscape crashes whenever I try to use it as a source however. Are you familiar with this and is there something I’m missing or do you have to enable it using their SDK first ? Is this something that’s on your horizon ?
Thanks,
JF
Hi again ! So I got confirmation back from the Devs at LIV that Enscape would have to implement their SDK for MR work on that platform. I have been trying and so far it just crashes Enscape. I’ve tried Mixcast as well and it won’t even recognize Enscape as a source. I’m giving OBS a shot now.
Has anyone else looked into mixed reality and realtime rendering ?
Thanks @jfmonod_1 , for your feedback. I’ve forwarded this subject to our developers - it seems that this is simply not officially supported by Enscape yet, which is why you’re experiencing these issues. It’ll be filed as a dedicated feature request accordingly.
Thanks very much Demian ! I look forward to this when your developers can get to it. The little PIP floating torso overlaid in OBS just doesn’t do the immersion justice.
Following up on this, looking at this tutorial : https://uploadvr.com/make-mixed-reality-video-livestream-two-realities/ it would seem that various options are available aside from implementing this or that SDK. I’ve tried LIV and it does make the 3rd person camera setup pretty easy. If you could add support for it that would be optimal, but allowing capture of multiple different cameras simultaneously as described here and then combining in OBS would be ok too.
Thanks,
JF
Hi all ! Just following up on this. Has anyone had a moment to look at Liv and weigh in on implementing it in Enscape ?
This is our use case here https://www.linkedin.com/posts/carbon-design-architecture_bim-vr-coordination-activity-6586334561909694464-GZkG
We use Enscape & VR for preconstruction services and coordination between disciplines. I’d love to be able to shoot these videos in a real mixed reality view.
Thanks !
