How to create frosted glass in Enscape
What is the best way to make frosted glass in Enscape?
add a reflection map/noise map into the reflection slot. i assume you are meaning the revit version. Revit also has native frosted glass in the material library
Thank you for your reply. The native Revit frosted glass shows up as green. Can I use a procedural noise map or should I use a bitmap?
Procedurals are not yet supported, but normal bitmaps should work. It shouldn’t look green for sure. Do you use the newest version of Enscape? If so, please send a screenshot to .
Still seems to be the issue in version 2.2.3.4 with Revit 2019
There is a similar thread here:
Revit Frosted Glass Transparency
