I’ve tried a lot of different ways to create spilled water on a hard surface
But I cant create a curved area with chamfered egdes.
Is there anyone who knows where to find a tutorial for this???
Thanx
Thanx
Im not sure what you mean by "I cant create a curved area with chamfered egdes. " but I can say that you can achieve spilled water with realFlow simulation. If you need just a texture map you can use wetmaps to get that effect.
yes..RealFlow rocks…glue3d is fun.
But if you insist on doing it 'ol skool,
don’t use extruded splines…You should
take the time to build it from a plane (plan view), extrude it,
then you can chamfer the edges and msmooth.
It’s not actually that painful..and you’ll feel like a
terminator if you pull it off…!
for water cant you just extrude the shape, then convert to editable poly, then selecting the top face use bevel. 1st bevel should be small extrude, tiiiny bevel. then a larger bevel. then a larger bevel smaller extrude and do that about 3 or 4 times to give an ok curve
that wouldn’t really work, cause the second you used a meshsmooth, it would look whack. And I dont really think beveling 3-4 times is really a doable function.
Hmmm Morbid, seems your Realflow advise needs a lot of training in a new program. (which I just started doing)
And Da_elf, I tried it, it takes a long time to get it “nice” but it was the best look I got till now.
Still wanna check out olitechs idea
thanx for now, but still not satisfied
i do it all the time and i dont need a mesh smooth for it
nice one. mine is more simple. 457 faces on mine. how many on yours?
WHAHAHAAHA
Whahahahaha
I ought to have know this would end in some kind of contest.
Olitech and Da_elf, would you be so kind to send me your water-mesh
And Olitech, and cant get a plane extruded
A little explaination would be greatly apreciated
you could probably use shell in his case.
1504 polys - 2 iterations
376 - 1 iteration
lol!..i wasn’t going for lowest polys
btw: i usually use Elf’s technique anyways ![]()
doh! i don’t think i saved the file, but…when u have the plane
set up, just go into sub-object mode> select faces> extrude (mine)
-or- >bevel (like Elf’s)
the main point of my pic was this:
you can’t msmooth if u use a spline for your shape…the verts will
converge in the center and pucker.
yes, i did 2 tries
-1 like the example above (using extrude)
-2 shell modifier (to get a bottom surface)
i preferred the results above for some reason
*come to think of it, i’ve been using Elf’s technique hardcore for a
golf community that we’re working on…no other way to control poly
counts
hehe. both of ours look good. just gave your way a try too. looked nice. both cases work. one of the main things with the water however which mine didnt portray well though since i just did it quickly (and didnt save it) is that reflections play alot in defining it. BTW i painted a wetmap in PS with softedges then in max i traced inside the wetmap with the spline.
I going mad
I get stuck at the very start
I create a plane (in standard primitives)
And thats where the fun ends
oh sorry..forgot to mention…you must collapse your primitive,
then you go to polygon selection in sub-object mode
Convert the plane to an editable poly (select, right click, convert to->) then you can select points, faces, edges and move them around
Once you have a shape you like, slap on the shell modifier like they said
Welcome to a brave new world of poly modeling. Soon you too will be able to model anything.
lolol
hahaha!!!
Yes, kick me when I’m down
I’m a AutoCad modeler (work related)
Trying to step into a better world
that’s the good way dude.
