Hi. I am looking for some suggestions for creating this kind of metallic material. It seems like it should be fairly simple, but I am interested in suggestions on what would be the best/easiest way to create it (e.g.: I was thinking of either a noise map or bitmap texture plugged into the base gloss and base bump - see attached material setup)? Anyone know what the name of this material actually is?
Check this one: [Accurate anodized aluminum](https://forum.corona-renderer.com/ Accurate anodized aluminum #msg150158)
