How could one add ISO, F-Stop & Shutter Speed info to the frame stamp?
Thanks for any input!!!
Well you could type it in your self. If you just want the info saved for the render.
Otherwise the code needs to be in there so you can just enter the appropriate code.
Usually %blah, you could try %ISO but if Vlado hasnt coded it, then it wont work.
Yes - that’s what I should have asked - what the appropriate codes are for ISO, f-stop and shutter speed.
Anyone know?
