Just noticed that after the latest update the intensity rays are enabled in the viewport every time a new light is created (plane/sphere). Is there any way to disable this by default?
It’s really annoying having to turn that off every time a new light is created. Viewport gets really messy when that’s on with a lot of lights in scene…
Hi, thanks for posting. You can use a script to turn off intensity rays. The command for this is
$.intensityRaysOn = off
Paste this command in a notepad file and save it as .ms file, for example RaysOff.ms
Select all the lights you want this checker disabled and paste the RaysOff.ms in your viewport.
Use the $.intensityRaysOn = on to reverse the process.
well… that’s handy but not exactly what I was looking for…
They still show by default whenever a new light is created…
I don’t want them to appear at all
Agreed. I don’t normally need them on and end up shutting them off for 95% of the lights.
No way to change the default behavior, I’m afraid. Here’s a little script to enable/disable the parameter for all VRayLights:
select (for o in $* where classof o == VRayLight collect o)
for each in selection do
case each.intensityRaysOn of (
true: each.intensityRaysOn=false
false: each.intensityRaysOn=true
clearSelection()
Make a button out of it.
Thank you though… That script assigned to a button does help! Appreciate it!
Max 2024.2 has an option to define custom defaults:
FUCK YAH!!! Yavor for the win!!! Awesome
