I know this. I thought about a default setting, to not have to do this for each new camera once again.
When I have a certain task coming repeatedly (I visited this “Show/hide cone” menu like 1000 times), I am thinking each time how it could be easier.
Here is a script you can bind to a hotkey. The script switches the ‘Show Cone’ option from Selected to Never and vice versa on the selected camera. Drag and drop the code from the script editor to a toolbar (it automatically creates a button), afterward edit the button (right-click>Edit Macro Script) and rename it (default should be “Macro1”), afterward open the hotkey editor (Customize>Hotkey Editor), find the button and assign it to a key.
s=$.show_camera_cone
s
if s<2 then $.show_camera_cone=2 else $.show_camera_cone=1
In fact, it does make sense, as it partitions the view and makes alignment easier (modern cameras all offer this, in one fashion or the other.).
If anything, i’d love for it to be expanded with more “grid” types: thirds, golden spiral, and so on.
And definitely stay active by default.
The only way you have to change the default is to create a maxscript plugin of the physcam, and disable the cone in the creation section of the plugin code.
You’d then however have to ensure you created the camera always from the plugin you made, and never (thereby losing a host of features) f.e. from the toolbar icon.
It’s unfortunately the way Max is.
However, you should not need to keep changing it a million times, either: within the single Max session, create the first camera, set its options (including cone), and any other camera created thereafter will respect those options unerringly.
Notice you should *not* create the camera from the toolbar, but rather from the creation panel for this to work.
