How to Disable the drspawner at boot up?
Can someone tell me how to disable the drspawner at the startup of Windows. I’m not really going to be using it for a while, at it uses a good amount of memory at startup? I don’t want to have to re-load and then call support for re-ativation Thanks in advance… JIM
jbwjim@comcast.net
Re: How to Disable the drspawner at boot up?
Hi jbwjim,
You should go to start then all programs and delete the DRSpawer of the startup folder.
Good luck
