Hi all. I have tried light gen for the first time just for the sake of it. And now i have some problem that all of my artificial lights being disable
I re-enable all of them manually but well, they just wont turn on. What should I do? The scene before the light gen was actually already render-ready with all lights & enviroment.
Thanks a lot
Hello @minhhanh_duong ,
Light Gen modifies the Exposure value, I suspect this is the reason for not seeing the artificial lights in the render after enabling them. You could try lowering the Exposure Value or increasing the intensity of the lights.
If you want to keep the lights in your scene you can disable the “Disable lights on application” option when generating variants with Light Gen:
Let me know if this helps!
Kind regards,
Iva
Hi Iva
it was indeed the case, thanks so much! Cheers
