How to enhance shadow in a scene
Hi everyone,
I have a little question,
How do I let those cabinet doors shadow obvious after the selected Secondary solver?
Thanks in advance
Eric
Which version of Corona is this? It looks ancient. :smiley:
It looks like there is some kind of light behind the cabinets, so it probably illuminates them from the inside.
What I sometimes do is I create a plane material and put it in between the cracks. That way I can control how much of the shadows are actually visible just by pulling the plane more inwards or outwards.
Surprisingly it works pretty well.
Oh and I apply a black material to the plane. :wink:
Talking about realistic rendering :smiley: dayyyumm :smiley: that is some advanced stuff moving the plane inside of the cabinets back and forward.
may be Corona Ray Switch material with black GI material---- some more simple variant than geometry option–:slight_smile:
Always used in Vray for this type white furnitures---- something like generate GI–0 in object properties///
Also possible to use corona AO map////—
I would like to suggest to properly model cabinets with empty space inside and check for correct reflectance of materials, but i’m affraid that response will be as usual - “we can’t remodel everything, it’s too much work!” :confused:
Thanks everybody,
Mine is Alpha 6.1, I tried many methods, even use Version 1.6 but still cannot solve, now only can put other material (grey) into to groove line. :frowning:
Holy crap, i think i just leave this here…
Cabinets.zip (6.66 KB)
Thanks for you samples :smiley:
