How to exclude object from casting shadow
Is it possible to exclude objects from light and casting shadow
Re: How to exclude object from casting shadow
You can turn off the global shadow, but not per object.
Best
There is a way for simple objects like surfaces and walls or background images …
http://forum.asgvis.com/index.php?topic=3782.0
“If the material is assigned to “Back”, than lights from outside comes through the wall …”
… it means, no shadow. I doesn’t work for polysurfaces, because the front surface will not be visible. It’s only good for surfaces, where the backface is visible.
