How to find what are the exact vray server version?
Hello, Is there an easy and fast way to find out witch build the servers are using?
Do you need to do this manually or from another tool?
I use remote desktop to log into the server but then after I’m unable to find the vray version currently on the servers.
Or can I use a DOS command to display the number of vray version on each servers?
thanks
I’ve always thought the DR server pop-up should show this and have requested this feature in the wishlist a couple of times. It would be very helpful if it is possible to grab that sort of info.
For the time being on my slaves I just RDP in to them and go to the windows and under [Programs and Features] I can see what version is installed for V-Ray.
Thanks, However you can’t see the built version like that…
You can always execute on the command line"c:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2017 for x64\bin\vray" -version
This will give you the V-Ray version and build number.
