how to fireChannel export to deepEXR
Hello.
I would like to export deepExr in phoenixFD.
I can export the smoke channel in volmetricGeometryMode, but not the fire channel.
How can I do this?
(If I turn off the fire channel and set smokeOpacity to the fire channel, I can export the closest deep, but the edges are not correct.)​
Best Regards.
It should be the same for the smoke and the fire - you need to use Volumetric Geometry render mode.
Could it be that your fire is using Fully visible Opacity Mode mode in the Fire settings?
You will need to use Own Opacity mode for the Fire in order to be able to see it in the Deep output.
Note that this mode will look a bit different and you will need to change your settings in order to match the look of the Fully Visible mode.
Cheers!
thank you for reply.
I had been rendering with the smoke channel as fuel,
but it looks like the one you showed me will be more adjustable and will export nicely!
Thank you very much!​
