How to fix jagged shadow edges in Enscape
Please advise how to make the shadows unjagged edges. See attached. I’ve tried the highest resolution to see if will make any difference. but I got the same result. Thank you
Does it help if you lower the shadow sharpness? Visual settings-Illumination-shadow sharpness
@feasinas , thanks a lot for your report and welcome to our Forum.
First off, if your “Field of View” is rather low in the Visual Settings → Main tab, please try to increase it and move closer to the scene. Additionally, please definitely make sure that you’re using our latest release. Alongside, does it help if you disable “Automatic Upsampling” in the General Settings? (found in the Enscape toolbar, context menu, not Enscape itself)
You can also reduce the Shadow Sharpness in the Atmosphere tab although that should not be necessary.
Finally, how large is the rendering itself just to know how much you’ve cropped into the image?
Demian,
Thank you for your reply. The image size was 22"x20" set in 4500 x 2650 res in Enscape output. then crop the portion of that rendering. here’s the second rendering after disabling the automatic Upsampling. Yes I am using the latest Version for Sketchup 3.0.1
I’ve experienced this too but not very often. Sometimes it caused by the height/bump in a material so I end up lowering the values. Also, I’ll do a PC restart, and that sometimes helps.
I was able to recreate your issues but only in the viewport (see attached) but at render time the issue resolved itself.
Also, I’m using 2.9
Thanks Jtubb, Pretty nice work online. :thumbup: I’ve tried few possible solutions but unsuccessful. If you look at the starbucks building, I was surprised, the worst outcome shadows. I hope I will get more advise to solve the problem, My last resort of correcting the problem is to bring in to PS and the problem solve :slight_smile: . Thank you
Thanks - Maybe revert to 2.9 and see if the issues remain?
